Tie Rod and drag link supposed to move?
Old 06-16-2011 | 05:54 PM
TxCop07's Avatar
Vet Army
Originally Posted by kotchulookin
I've been trying to diagnose this clicking under my front end, and i noticed the play. it doesn't sound exactly like the noise I get when I go over bumps, but it is possible. can you get any type of firmer bushing for these, so that they dont clunk or is an upgrade, pretty much the only way to go?
I believe Moog sells some.
Old 06-17-2011 | 12:09 AM
TRAUMAhead's Avatar
Originally Posted by Danabee
I was having the same issue today, I can understand some play, but, should it be so sloppy that is sounds like rocks banging on the undercarraige?
Dan
That's what it feels like at 70-75+ MPH, directly under the driver floorboard, no sounds though. I've checked under the Jeep, couldn't find anything. Figured it might be the mud shield.
Old 06-17-2011 | 05:41 AM
STUPIDFACE's Avatar
Originally Posted by TxCop07
Has anyone replaced the tie rod ends with some like Moog ones?
I have a moog end on my afer market drag link. I have no complaints.
Old 06-17-2011 | 07:29 AM
TxCop07's Avatar
Vet Army
Do they fit the factory center piece? If so do you know the part number?
Old 06-20-2011 | 08:00 AM
STUPIDFACE's Avatar
Check out this thread...
https://www.jk-forum.com/forums/show...og+tie+rod+end
Old 06-20-2011 | 05:09 PM
TxCop07's Avatar
Vet Army
That is for the draglink though. I was wondering about the TRE. Anyone know about them.
Old 08-14-2011 | 10:23 AM
glwood6's Avatar
Moog sells replacement ends for the tie rod. I ordered them. Unfortunately, when I went to install them, I found out that the passenger side tie rod end is not removable or replaceable with an aftermarket end. I could have replaced the driver's side end, and that would have helped a lot with the slop, but I decided to send back the ends and get two drag link ends to use with a new RK tie rod.
Old 03-23-2018 | 06:15 PM
easy fix's Avatar
Thumbs up Are your tie rod ends loose?
If you suspect you have loose tie rod ends here is a fast and easy way to check your Jeep out! I hope it helps! ~shaun
Old 03-20-2021 | 08:34 PM
Audra Perry's Avatar
Default Bad Drag link or bad auto shop?
I have had no problem with my jeep. My tires were old and getting bald so I bought new ones and forgot to get an alignment. Went in for an inspection and failed. Was told that I have to replace drag links because of too much play in the wheel. (Not a reputable place). Can not having an alignment cause it to fail inspection?
Old 03-21-2021 | 05:43 AM
karls10jk's Avatar
Not having an alignment won't cause a failure for inspection but if the ends have excessive play then they can fail you.
When they say "too much play in the wheel"- are they referring to the steering wheel or a wheel on the ground? Some states do dictate an amount of allowable play in the steering wheel but usually movement at the wheels will be ball joints or wheel bearings. There's a lot more money to be made on ball joints, potentially wheel bearings as well with the price mark up's.
Quick Reply: Tie Rod and drag link supposed to move?
