Taking the doors off
Old 04-13-2008, 02:16 PM
birdfish316's Avatar
Default Taking the doors off
Can someone please tell me how to unhook the little plug thing so I can take my doors off?
Old 04-13-2008, 02:21 PM
Jordo89's Avatar
slide the little red thing over and press down of the button-y thing and pull.
Old 04-13-2008, 04:33 PM
SH0RTBUS's Avatar
That will allow you to undo the wire harness thing. Then you will have to undo the strap thing from the hook thing. Then all you need to do is remove the bolt things from the hing things and the door things should come off.
Old 04-13-2008, 04:44 PM
Jordo89's Avatar
make sure to roll down the window thing before you unplug the plug thing. it will give you a place to stick the thing on top of your shoulders through so you can lift up. oh and i recommend some lithium grease on the bolts for the hinge things before you put the doors back on. otherwise they get hard to take off after a while.
Old 04-13-2008, 05:26 PM
BJeepJK's Avatar
push the red tab (lock) right to left, or left to right. Then squeeze the bottom front to back and pull down.
Old 04-14-2008, 11:14 AM
Default Thanks!
Thank you everyone. I really appreciate it!!!
Old 04-14-2008, 11:35 AM
pkess3's Avatar
I had trouble with this yesterday. The stinking red thing wouldn't budge!! I've done it before on the hard top's wire harness but this has been a pain!!
Old 04-14-2008, 01:08 PM
snowbdr88's Avatar
Wink Mirrors
I bought and use the outlaw mirror things instead of moving my stock mirror things.
I keep the outlaw things under the seat things.
Old 04-14-2008, 02:59 PM
DeepSky's Avatar
LOL you guys just gave me my laugh of the day
Old 04-14-2008, 04:45 PM
Cruiser's Avatar
If your having issues with the little red tab,, just remember if its a PIA your doing it wrong. Calm down and try another door.. see if it works better there.. if not,, a hammer and cutting pliers should also do the trick..
Quick Reply: Taking the doors off
