sway question
sway question
is the e-disco the electric sway bar disconnect? Is there a way to disconnect the sway bar on an x without the electric disconnect? How difficult?
Just by some disco's they arn't expensive at all! Teraflex and HKS have nice sets. I have EDisco and the Teraflex manual disco on at the same time.. (Teraflex ones came with my 3" lift kit)
Installing them is super easy! 4 bolts total!
here ya go...
Teraflex quick disconnect write-up:
http://project-jk.com/jeep-jk-write-...s-installation
Go here. It's an old thread on a do it yourself disconnect that's quick, easy and cheap. Try it first and if you think you like it, it may be all you need.
https://www.jk-forum.com/forums/show...light=diy+sway
If you don't even want to spend that money, then just crawl under the JK and remove the links that attach to the stock, unmodified sway bar. Swing the sway bar up out of the way and secure it where it won't do any harm. The nuts on the links are similar in size, but not identical--so rethread them onto their respective bolts so that you don't get them mixed up. Depending on your tools (IIRC, an 18-mm ratcheting box end will be perfect), maybe a five-ten minute procedure.
Here's one of the links you're removing; the stabilizer bar is coming in from the top of the image:
