Sway bar disconnects
#26
Got the stuff at Tractor Supply Co. $9, and put them on! I ended up using basic cotter pins until I can get the holes drilled to 3/16. Just have to take em back off and use the drill press at work in the maintenance shop. I may try different washers too because as of now I have to use the end hole in a 2.5" pin and it slides around, if I can get it in the second hole it would be nice and tight, and tight is ALWAYS good!!
