Sway bar disconnects
Old 03-23-2014, 05:42 PM
trouty33's Avatar
Originally Posted by kh202
Yes, that's all I've ever used on both my JK's. Only thing is, it isn't a 100% perfect tight fit, so you may hear a jingle over speed bumps. Other than that, they work perfectly fine and take 30 seconds to disconnect.
Sweet!! Thanks! I'll be heading to the hardware store this weekend!! As for the jingle I'm half deaf anyway so as long as it's safe I'm set!
Old 03-23-2014, 06:50 PM
D3ADLY's Avatar
I drove and used my $8 home made quick disconnects for about a year and a half and they worked great. I don't think you'll have any problems.
Old 03-23-2014, 06:57 PM
bushpilot's Avatar
damn, where were all you guys before i bought my JKS quicker disconnects
anyway i still like my JKS Quicker Disconnects....
Old 03-24-2014, 05:09 AM
trouty33's Avatar
I was looking at adding quick disco's but for the price difference I'll do homemade accomplish the same thing and put the money toward the next item, which I'm leaning towards a hi lift or trail lights. I may even swing by the hardware store today since I'm off and have the jeep at the dealer anyway. They owed me a hitch from when I bought it!!!
Old 03-24-2014, 05:10 AM
trouty33's Avatar
Anyone have pictures of using the clevis pins?
Old 03-24-2014, 05:41 AM
kh202's Avatar
Best I could do
Old 03-24-2014, 07:16 AM
1meand's Avatar
Best I could do
Attachment 540118
That looks like a fairly snug fit.
Old 03-24-2014, 08:42 AM
chopperbobby's Avatar
On the Clovis pin do they come in different hardness. Like bolts. 8.8 and 10.9.
What length?
Old 03-24-2014, 08:57 AM
trouty33's Avatar
I did some searching on here and there is good info in a thread named "Home Mod Sway bar disconnects" thanks for the pic! I stopped at home depo but the didn't have the right pins to hold it in place. I'll try the local hardware store this afternoon. Then to find a better way to keep them out of the road when disconnected... I'm gonna try and find a place to put a bolt that they can be connected.
Old 03-24-2014, 09:05 AM
Gforce!'s Avatar
Location: Independence and Lexington, KY (depends on the time of year)
I also have been running the "poor man discos", and i have about 20k on them. You may want to paint the clevis pins if you're in an area that uses a lot of salt in the winter, as mine have some surface corrosion, but it's nothing too bad. They clink when it's warm outside, but they're safe as far as I'm concerned. I figure if a bolt the same size can be used to hold the engine to its mounts, it's safe to use for discos.
Quick Reply: Sway bar disconnects
