Suspension Question
Suspension Question
I have a puck lift to go on my JKU. I saw one today with the same lift and instead of using longer swaybar links they changed the angle of the swaybar. My question I will this work or is it just a temporary fix.
You really want the swaybar to be as parallel with the ground as possible. Too much on either side of level will affect the handling of your Jeep.
What size pucks are you installing?
That's because they're either lazy or just don't know what they're doing If yours came with longer links i would definitely use them. My 2.5" bb came with new rear links, and the stock rear links get moved to the front. Keep in mind tho, if you install longer links in the REAR, it may come close to rubbing the wheel/ tire if you are still running stock wheels (unless you have spacers). You'll see what i mean. Wheel spacers or aftermarket wheels with less back spacing takes care of this issue. On my 2.5" Teraflex bb, just took my rear swaybar off for a few days until i got my new wheels/ tires.
Yeah you can. I didn't really feel much of a difference onroad. I would get new rears eventually tho if you do a lot of off camber stuff. Gives better stability
