Strange sound coming from JKU
I have noticed a strange sound coming from under my 2009 JKU at highway speeds. I really don't hear it while tooling around town. It is kind of hard to describe, but I will do my best. It is kind of a dull rattle. It sounds like it is coming from in front of me, but I can't tell exactly where it is coming from. It almost seems like I can kind of feel it in the floorboard as well.
Thanks in advance.
Thanks in advance.
Had a similar experience with my '08 JKU with 37k miles. Started out as a low growl and would vary with speed. Could also feel in pedals. Began to get more noticable.
Took it to the dealer and it ended up needing new wheel bearings.
This is more of a rattle than a moan or grawl.
It is going to sound wierd, but it almost sounds like boiling water that I can hardly hear.
Check the plastic shield thing (name escapes me) under the front bumper. My buddy's started to come lose and rather than repair it he simply tore it off. Noise disappeared but he's left a little unprotected now.
My 2011 had a thumping sound coming from in front of the dash area. I popped the hood shook everything and found the dual heater lines running side by side into the firewall, middle of the jeep was the problem. The rubber trim around them was lose. I took a zip tie around them and tied them off to the side to hold them in place.
Did some checking tonight and realized that I don't believe I have the air dam below the bumper.
I did pop the hood and found a wire harness located near the battery that was very loose and rattling against the bracket it is attached to. I zip tied it tight so I will see if the helps.
Another thing I didn't think about until tonight is that I took the sheet metal right behind the hood off and plasti dipped it a few weeks ago. I demolished the four push screw that held it down in the middle. My plan was to pick up some new ones, but haven't had a chance to so that yet. It may be rattling at higher speeds. I will pick some up tomorrow and see if either of these two issues were causing it.
