Strange humming sound
Old 11-18-2014, 10:26 AM
SebasCbass's Avatar
Default Strange humming sound
Forgive me if this has been posted somewhere else but I have been looking and can't figure this out. So here goes.
Jeep is stock and only has 33 inch Duratracs on it. When driving at around 65mph there is a strange humming sound that I can hear and feel ( slight vibration ) coming from which seems to be the front of the jeep. I feel it in the gas pedal and then it magically disappears.
I originally thought it could be the tires but I just bought a new set of Duratracs ( 2nd round with them ) and it is still happening. Not really sure how to describe the sound but it sounds like a little CRV with a massive exhaust on it, just not as loud.
Once I hit anything over 65mph it's gone and anything before that it's not there. Everything is aligned correctly, new tires are balanced properly and I know it's not the humming from the tires ( Duratracs are pretty quiet ).
Is it a leak? And if so, wouldn't the humming be there no matter what?
Thanks!
Old 11-18-2014, 06:16 PM
Jiblet's Avatar
Maybe check for loose/vibrating heat shield.
Old 11-19-2014, 05:04 AM
Wrangeler X's Avatar
Sounds like a driveline vibration to me. Check you drive shafts and pinions for any play
Take it in to a driveline shop and have them take a look.
Old 11-19-2014, 05:28 AM
tribulation138's Avatar
Hmm. There is lots of noises at 65+ mph with a jeep.
Maybe wheel bearing
Old 11-19-2014, 06:56 AM
JTB488's Avatar
What tire pressure you running?? I have a friend that run's Dura's and he commented they are a little noisey.
Old 11-19-2014, 11:28 AM
SebasCbass's Avatar
Running them at 36psi. They are pretty quiet for having an aggressive tread pattern. Maybe I'm just used to them
Old 11-19-2014, 11:29 AM
SebasCbass's Avatar
Ooooooo I didn't even think about that. Will def take a look. Thanks for the input.
Old 11-19-2014, 11:43 AM
SebasCbass's Avatar
I'll check to see if there is any play. Hopefully I can find out what is causing it.
Old 11-19-2014, 11:45 AM
SebasCbass's Avatar
Maybe wheel bearing
Ain't that the truth. This is my 4th Jeep so I am used to all the interesting noises the jeep makes.
Just want to make sure nothing is going bad on the jeep.
Old 11-20-2014, 12:35 AM
JTB488's Avatar
To rule thing out thy running 32 psi. If still noisesy try the upper like 38-40 psi. How long has this set been on mileage wise?
Quick Reply: Strange humming sound
