Stock Spring issues?
Just curious if anyone has any idea what could be causing this? A little back story, a few months while installing a teraflex leveling kit I opted to install a set of 18 springs from another JK to replace my 17's....fast forward to yesterday I was test fitting some wheels and tires and noticed what you see in the picture. the spring appears to be seated in the perch at both the top and the bottom.....but its bowing out in the middle...so much so that I believe on occasion it hits the sway bar! the passenger side does this as well but not as bad and its bending towards the rear. Any ideas? thanks
When you lift a Jeep the axles rotate. That shifts the spring perches from being straight up. For a couple inches of lift, RK wedges or similar products will fix it. I've not heard of anyone having problems with springs bowing on the front axle. Perhaps because they are longer, smaller around, and in a more open space.
