stock sahara springs? stock rubicon springs?
#22
Originally Posted by breadfan507@gmail.com
OK so I have 59 in the rear and 15 in front...any suggestions..mind you I'm getting Rubicon springs! Do Rubicon have bigger springs in the rear
#23
#24
Originally Posted by Wazzu51
What was your initial spring rate, and did you just swap stock rubi springs in there?
Thanks
#25
Originally Posted by Delux2769
It's one I made. For about $30 at Home Depot.
It took me an afternoon to do. I left it 48" wide and cut it about 72" long. I put about 14 grommets in it. The best deal I believe in this is that I can take out the front 3 ball bungees and put my soft top up.
I'll post up the thread write up in a min.
#26
https://www.jk-forum.com/forums/show...ni-top-project
Basically I laid out the mesh, took a piece of tape about 1"x1" at each spot I planned to place a grommet. I measured from the edges, and made the spots. Once I had the main spots planned out, I tapped in the grommets.
I put the top up and used the ball bungees to strap down nicely, then planned out for the rest of my spots to keep flapping to a minimum.
In the 100'+ heat this Texas summer it blocked the sun, still allowed light and held up to rain for months so far. Extremely sturdy as well. My 70lb dog hopped up there several times on my roof.
#27
My new Rubicon Unlimited came with 18/59. It's my understanding it depends on the accessories you jeep came with as to what springs you get. Higest rated springs come on Rubicons with Dual Top, Max Tow and Auto Transmission.
