stock sahara springs? stock rubicon springs?
Old 10-31-2011 | 02:06 PM
  #21
breadfan507@gmail.com's Avatar
OK so I have 59 in the rear and 15 in front...any suggestions..mind you I'm getting Rubicon springs! Do Rubicon have bigger springs in the rear
Old 10-31-2011 | 07:03 PM
  #22
Delux2769's Avatar
Your rear springs are great, you'll just need to swap the fronts if the numbers are higher.
Old 04-30-2012 | 03:42 PM
  #23
Wazzu51's Avatar
Default Rubi Shocks
Originally Posted by Delux2769
Here's a before and after pic of my Rubi coils and shocks swap. The shocks just made the ride helluva lot nicer.
What was your initial spring rate, and did you just swap stock rubi springs in there?
Thanks
Old 04-30-2012 | 06:08 PM
  #24
Delux2769's Avatar
Thanks
My initial springs were 14/55. I also just did a straight swap. Dropped my old ones out, and stuck the new Rubi ones in their place. Same with the shocks.
Old 05-01-2012 | 01:36 PM
  #25
jeeps_187's Avatar
It's one I made. For about $30 at Home Depot.
It took me an afternoon to do. I left it 48" wide and cut it about 72" long. I put about 14 grommets in it. The best deal I believe in this is that I can take out the front 3 ball bungees and put my soft top up.
I'll post up the thread write up in a min.
have you done a write up for this idea?
Old 05-01-2012 | 06:12 PM
  #26
jes1848's Avatar
https://www.jk-forum.com/forums/show...ni-top-project
Basically I laid out the mesh, took a piece of tape about 1"x1" at each spot I planned to place a grommet. I measured from the edges, and made the spots. Once I had the main spots planned out, I tapped in the grommets.
I put the top up and used the ball bungees to strap down nicely, then planned out for the rest of my spots to keep flapping to a minimum.
In the 100'+ heat this Texas summer it blocked the sun, still allowed light and held up to rain for months so far. Extremely sturdy as well. My 70lb dog hopped up there several times on my roof.
Can you please explain the cut cupholder mod and the dash gap mod? along with all of the home mods?
Old 05-01-2012 | 07:25 PM
  #27
lazerpunk's Avatar
My new Rubicon Unlimited came with 18/59. It's my understanding it depends on the accessories you jeep came with as to what springs you get. Higest rated springs come on Rubicons with Dual Top, Max Tow and Auto Transmission.
Quick Reply: stock sahara springs? stock rubicon springs?
