Stock to Rock questions
Old 05-03-2017 | 05:59 AM
resharp001's Avatar
Originally Posted by MyWhiteJep
Thanks guys. I decided to run 3.5" Rock Krawler, 37" Nitto Ridge Grappler, KMC XD Monster II rims, Bilstein 5100s, Yukon Gear 4.88, and Yukon Dura Grip rear lockers.
Just keep in mind to budget a new front DS if you don't do it immediately. Also budget to replace ball joints if you still have the factories. If you're going to run 37s you might want to budget for Dynatrac or Rare Parts. Also, if you're axle is completely stock, at least throw some gussets on it. If you don't flip your drag link, prepare for a little bump steer. You're jumping in the deeper end and will realize how much other stuff needs to be addressed once you do.....so just stay prepared so you don't have any rude awakenings.
Old 05-03-2017 | 06:43 AM
numbah1's Avatar
Vet Army
Originally Posted by nthinuf
That is a clutch-based Limited Slip, not a locker. A Detroit Truetrac would be a better choice for a limited...
I run Truetracs (front & rear) in mine. I love this combination.
Old 05-03-2017 | 07:02 PM
tarpon4me's Avatar
Veteran: Air ForceJK-Forum Ambassador
If you keep the lift at 2.5 inches, you'll avoid a lot of the aforementioned issues with drivetrain, suspension and steering geometry, and save a ton of cash. With flat fenders and proper bump stop, you'll still have plenty of room for 37 inch tires. I have a 2" lift and flat fenders and I can easily clear 37 tires. I'm sticking with 35 though because of my Dana 30 up front.
