Stock fogs
Stock fogs
I am putting a new (to me) bumper on my X, it has cutouts for fogs, but I dont have any. Is there a good (cheap) fog light I can install? What size are they? How should i wire them?
Thanks,
Joe
Thanks,
Joe
Good luck. Don't forget to post pics when you're done!
why on low beam???
can anyone explain why the stock fogs are wired to only be on when the headlights are on low beam and turn off when you switch to high beam? If i need more light on low, i would also like more on high. Can they be re-wired to work with the high's instead of the lows?
It's a federal code. All factory fog lights work that way.
I'm sure you could rig something up, but in my opinion getting a set of Hella European Beam Driving lights (or even replacements for your headlights would produce a MUCH more satisfying light pattern than trying to run High and Fog together.
