Stock Fender Removal?
Old 10-01-2011 | 09:51 AM
hoveyjk08's Avatar
Default Stock Fender Removal?
I need to gain access to my o2 sensor the passenger side. Is there a good way to remove the
fender without ruining all the clips? Any help would be appreciated.
Old 10-01-2011 | 10:44 AM
ABQ_Dave's Avatar
Having removed my fender to replace them entirely, I'd say no. You're going to break most of the clips. So, plan ahead, have some clips on hand. However, don't buy the OEM ones from Mopar or whoever as they're ridiculously overpriced. 5.99 per clip on Quadratec. Another thread from a while back listed these hxxp://www.clipsandfasteners.com/Chrysler_Moulding_Clip_Gray_Nylon_p/a20887.htm They do appear to be nearly identical to those on the Jeep and at 15 per package for 9 bucks, it's not bad.
Break the originals off slowly though as the sheet metal is Coke can thin and will bend if you hack at it.
Old 10-01-2011 | 10:49 AM
hoveyjk08's Avatar
Did you have to remove the inner fender to remove the fender? What about the clips connecting the fender to the inner fender?
This is on a 2008JK if it makes any difference.
Old 10-01-2011 | 12:30 PM
GreenJKr's Avatar
I removed the whole fender assemblies to install flat-fender style flares. I noticed the outers were fastened to the inners with press in plastic, rivit-style fasteners. You can punch them out with a small hammer and a 1/8" punch. You may be able to find the replacements at an automotive supply store.
Old 10-02-2011 | 05:44 AM
RedJK2's Avatar
In my limited experience with chopping fenders, I think it's impossible to save the plastic rivets. However, the clips should be salvageable if you're careful.
Harbor Freight Tools sells a rivet gun packaged with a bunch of plastic rivets (Item # 97757).
Old 10-03-2011 | 11:29 AM
hoveyjk08's Avatar
Thanks a lot for the advice. I will be attempting this tomorrow before work.
