Stock Fender Flares
Old 04-02-2009, 05:55 AM
JeepPilot88's Avatar
Default Stock Fender Flares
Are the flares the same on 2 Door and 4 Door?
I have a 2 Door, just want to know if I could put flares off from a 4 Door on it. (After I chop them up of course)
Old 04-02-2009, 06:21 AM
STUPIDFACE's Avatar
yep.....
corey d
Old 04-02-2009, 06:51 AM
JK Rocker's Avatar
I'm not positive, but I thought the rear flares were slightly different.
Anyone... am I wrong?
Old 04-02-2009, 07:17 AM
STUPIDFACE's Avatar
I have 4 door chopped flares on my 2 door. They may be slightly different, but they work.
corey d
Old 04-02-2009, 09:27 AM
Those look great!
What do you have for a lift and tires?
Old 04-02-2009, 11:18 AM
STUPIDFACE's Avatar
Those look great!
I have a 3" suspension lift with a 1" body lift. The tires are Mickey Thompson Baja ATZ's (35 x 12.5 x 17). I like it but i will eventually put a 4" long arm lift and different rims and tires.
corey d
Old 04-02-2009, 02:25 PM
pastorsteve's Avatar
Looks great. What did you cut them with?
Old 04-02-2009, 02:28 PM
4x4jkx's Avatar
I was just about to ask the same thing. You got me considering it when I get larger tires.
Old 04-03-2009, 08:56 AM
JK Rocker's Avatar
Some have used a knife, others a dremel with cutting wheel, and I think someone even used a jigsaw. The key is to cover the edge with adhesive door trim, which really cleans up the cut and gives it a nice finish.
Old 04-03-2009, 09:35 AM
JK-Tex's Avatar
For those uninterested in doing the work themselves (for fear of screwing it up), this would be a really easy job for an automotive upholstery shop. They would also have ways of cleaning up the edge, including the use of door edge trim as previously recommended.
Quick Reply: Stock Fender Flares
