Stock 2012 jkur with 35's....possible without lift?
Thinking of adding 35's to my 2012 JKUR. No lifting wanted. can it be done with no rubbing issues?
Willing to use spacers. any recommendations on brand and size?
thanks!!
thanks!!
Do you plan on going off road? If so, you'll need wheel spacers or wheels with 4.5" of backspacing and longer bump stops or flat fenders. With the Rubicon you'll have to shorten the aft end of the rock slider and trim the pinch seam.
People have done 35s at stock height. However you will have to run flat fenders and trim a lot of plastic. If you don't go offroad it's probably going to look squished but will work. Personally I'd run a 2.5" budget spacer lift which will keep the stock ride but keep you from rubbing or cutting up your jkur.
As for the width you will need to run 1.5" wheel spacers for wheels over 11" wide.
Thread jack. Can someone run a 2 inch lift and be ok with 35's. Stock rims with 1.5 inch spacers? I wheel and don't want any rubbing issues either. I'm torn between the aev 2 inch lift and the 2.5 Tera budget.
Sponsoring Manufacturer
OR-FAB
OR-FAB
