Still gas odor after fill up
Lynne Bridges
The issue would be coming from either the fuel pump or the lines leading to the pump. The lines are not secured enough from the factory and over time, these connection can weaken cause fuel to be dumped onto the top of the gas tank. The only options would be to have someone drop the gas tank check the fuel pump and lines and see if there is any staining on top of the tank. If there's staining, its due to over flow or the weak connections and the fuel just sits on top of the tank for a while. The other option is pressure wash as much of the top of the tank after a fill up. Ideally, do not over fill the tank.
I have a 2008 Jeep Wrangler Unlimited and have gas fumes inside my Jeep. Took to dealership and they did a smoke test and also checked all lines and said no broken lines. Think they just assumed must be the fuel tank so after spending close to 2,000 was replaced. Well, problem still exist so have written down all the above suggestions and will be taking back to the dealership. I am a 68 year old female who loves her Jeep but am not knowledgeable about servicing it
myself. I am planning my yearly trip cross country in a few months so really want this issue resolved. Travel alone and the roads in Wyoming into Jackson hole can be pretty isolated. Really appreciate any suggestion you can give me when talking with the mechanic. Live in Columbia, SC
