Steering shaft makes a difference in ride over bumps?
So lately I have been getting bad shaking over bumps (not DW).
After torquing EVERYTHING with a torque wrench I decided to replace the steering shaft.
I did not have the steering clunk (i know what that is) but it had been a year since I put the last shaft in and I know the U-Joints on that thing are not the longest lasting, so I figured why not.
I put in the new shaft and its MUCH better. Now the question is can the steering shaft really make the Jeep feel like its falling apart or is the new shaft just masking something? It seems if it wasn't the shaft it would be even more pronounced now because the new shaft is in tighter spec, no?
I just had the upper and lower shafts replaced(under warrantee) for the clunk and the front end feeling loose. It really did tighten up the front end so I guess the answer is yes, it really can cause that much noise and vibration.
Dave
Dave
I just fond that the u-joints on those shafts are fairly cheap. They wear overtime (although there was no visible play replacement made a difference.)
