Stealership Recommends... Taken with grain of salt?
So i went to get a leaking diff sealed and amp flashed on my warranty, and while i was there the service tech recommended the following.
For my 30k service he recommended
Throttle Body Service - $129.95
Brake Fluid Flush - $125.00
Fuel Injection service - $25.00
And a New Air filter - $51.32
So how plausable are these... I can do my fuel injection service (guessing injection cleaner mix), i was going to go custom intake or K&N, but for the brake fluid flush and throttle service i'm not so sure how to proceed.
How can i drain the brake fluid?
What is a throttle body service... I'm guessing i open it up and clean it with something?
Besides that the front diff fluid has been replaced as part of fixing the leak. Does the rear diff need to be flushed as well? How about my trany fluids, power steering, and etc...
I know theres a few posts that goes through the rest pretty well, but i'm wondering if i "need them" or not. When did you guys do these maints?
honestly I have never heard of a brake fluid flush.... ever on a new vehicle
redneck said something about fuel injection cleaning is not needed on these high pressure fuel systems
it is easy to clean your own throttle body if you see excessive build up in it
and I think everyone can change there own air filter.
So it just depends what you have more of....... time or money?
can't speak from personal experience of having problems but brakes get very hot and any of water in the fluid can vaporize forming bubbles in the brake lines. bubbles are compressible leading to poor performance.
I believe GM has a lifetime fluid (because of additives) but Ford calls for changes at 36k miles. Others (BMW) say change it every 2 years. (That is my plan, 2 years from build date)
As for your air filter; just buy one (~$15) and do it yourself. Truly the easiest job on the vehicle!
The FI and TB stuff is ridiculous.
The rear diff is a little more involved but still very easy, see the write up. I would do the rear diff to match the front. The change is easy but be prepared to take the cover off and hose it down with brake cleaner if the old fluid is milky or otherwise nasty. By the way gear oil stinks, so a bad smell is not a problem.
EDIT: Also, fresh fluid is clear-amber; "wet" fluid will be darker and cloudy. And I know nothing about the DOT 5 stuff other than it is NOT compatible with DOT 3 or 4.
Those f'ing morons are are a bunch of crooks. 50 dollars for an air filter and a 120 for a brake fluid flush. Im suprised they did not offer a new paint job for 6000. Its a jeep, learn to do all your own work. I refuse to let those morons touch my rig unless the computer frys.
you definately have to change brake fulid. people never change it. like trans fluid. then you develop problems. changing brake fluid is pretty easy. they sell vaccum pumps with tanks for changing them. fill resovoir under hood with new fluid and suck through the bleaders on calipers. start with farthest corner and work twards driver front.
After 46 years of driving, I have never changed the brake fluid on any car, truck, or Jeep (having owned 7 Jeeps). This is robbery. This will not void your warranty.
