Stbby antenna
Stbby antenna
I'm looking for a decent stubby radio antenna that will still get a good signal (if that possible). My original antenna hits the garage door when I pull in after the lift.
Not sure on a good stubby but i would just cut off an inch or 2 to clear the garage, then put a little cap on the tip to replace the ball end so you will avoid the sharp cut end.
Stubby Antenna
I replaced mine shortly after I bought the vehicle. Regretted it immediately. It's fine in the immediate Bay Area, but but not worth a hoot for receiving AM if you travel away from the bay.
I just installed this 13 inch antenna from Amazon. It seems to do a great job thus far.
Amazon.com: Off-Road (13" inch) ANTENNA - 2007 thru 2013 Jeep WRANGLER Unlimited JK: Automotive
I have had no luck with stubby antennas. I even replaced my stock one wuth one that was a couple inches shorter to no avail.
It seems they have to. Clear the top like the stock one. I did get a black one that was the same length as stock. Works fine.
