start up problems
start up problems
on two occasions engine barely turned over for two to three tries, then started. Have new yellow top optima battery. Someone got a suggestion?
when it doesn't start, is it just a click and then nothing? I've been having the same problem. They've replaced the starter twice and had it for 2 weeks total and it still does it
This seems to be a growing problem.
Has anyone tried replacing the engine ground strap? Maybe just add another one, directly from the battery negative terminal.
Had the same problem once when off roading on a hot day. Stop and start all day long and then nothing . Would not turn over , could not boost it and could not pull start it. Like it was not reconizing the key. Pulled the cables off the battery and that reset the computer and all was good. No problem since. try that an see.
Try this thread there has been alot of us with similar problems. I had my range sensor changed and haven't had any problems since. It's a long thread so grab a brew and read up.
https://www.jk-forum.com/forums/show...p-Not-Starting
