Squeaking noise!!! Please help!!!
Ok, so I've noticed while driving when I apply the brake I can hear a squeaking noise. Almost sounds as though it's break related, but I've had the brakes & components looked at twice in the last 2 months and all is good. The sound is driving me nuts!! I can't pinpoint the exact location of the sound...just sounds like it's in the axle/wheel/break area....Sounds like I am driving around a P.O.S....the Jeep is all stock and a manual transmission w/about 38,000 miles. I've looked for debris that may cause issues an nothing! Any ideas???
It is only when breaking...with slight pressure. Once I put more pressure down to stop it goes away. I've had the pads/rotors and everything checked out and it's good. No idea where this damn noise is coming from....
VERY INTERESTING! I just started to get the exact same noise! Only when lightly breaking and it is driving me nuts!! 32000 miles and a 6spd...I can't figure out what it is!
Sounds like either the pads/rotors are glazed or the brake hardware needs to be lubricated. Tear down the brakes, have the rotors turned and the pads scuffed (you can do this by rubbing them on concrete). Clean all of the surfaces with brake cleaner. Reassemble using brake lube on all the moving parts that are metal to metal. The noise should be gone.
Is it the rear? If it is pull the caliper and rotor off and check the axle flange. I just started the jeep and put it in gear and watched the flange on the axle. Mine was tweaked and wobbling causing that squeak squeak squeak. Mine started out only doing it under light braking but then it got to the point were it was doing it all the time. Good luck!!
