Squeacking underneath the Jeep
I've been hearing this annoying squeacking coming from underneath (cant determine exactly which side) ever since I lifted the Jeep. You can see in my signature the details of my lift. The sound become more persistent and constant on bumpy roads.
Could it be the driveshaft hitting the transmission? or maybe the driveshaft Ujoints or rear axle Ujoints?
I dont wanna mess anything underneath the Jeep before diagnosing the problem so any suggestions is really appreciated.
Originally Posted by dgnr8
Thats Normal Sir.
Hose a section down with WD40, drive a bit and see if that makes it go away. Once the squeak goes a way, you've narrowed down the problem, or at the very least you can determine where the squeak isn't. I would look for contact between the springs and the body and at the rear right shock and rear right bump stop (personal experience). I seem to recall a problem with the boot on the front drive shaft occasionally rubbing on the automatic transmissions, but that would just wear a way. I think it's unlikely that it's your u-joints if you noticed it right after installing the budget boost. You can give the u-joints on the drive shafts and the front axle a good shaking and see if there's noticeable play in them though.
