Sqeaking noise while accelerating and braking
Been having this issue since my JK was new, about 2-1/2 years (60,000 miles) ago. Started out as a minor squeak when braking so the dealer replaced all pads and rotars twice. Then they performed a front diferential service that was a bulletin from Chrysler. Now the noise is getting really bad. It mostly occurs when accelerating or slightly trurning and sounds like it's coming from the drivers side rear. The noise can be heard when cruising at highway speeds and when braking. I just had the rear brakes done again (worn out) and the noise still persists.
Anyone have any ideas?
2007 JK Sahara Unlimited, auto
Thanks!
Thanks!
Thanks for the info. It sounds more like it would be the bearings rather than the spring seats because it's a constact sqeal sound. I'm goint to try a third dealer this week.
if your jeep is still under warranty it will be replaced free if not i would suggest you find a local person to do it for a hell of alot cheaper....
BTW i like your setup man
solution
Well, Hayes Jeep in Gainsville, GA was able to diagnose that, even though the sound appeared to come from the rear end, it was a leak in the throttle body. Go figure. Anyways, they replaced it and the annoying sound is gone.
Thanks!
Thanks!
