spark plugs
#21
The same thing happened to me with the plug wire, I just rebuilt it and lubed them before I put them back. Now the lesson I learned is the plugs are not worth buying (E3's) but I did find that the factory plugs the gaps were all over the place. So all I can tell you from my experience is to check the plugs and don't replace them just clean them and regap them. I am going to replace my plugs back to the factory plugs but I also am not looking forward to that pain in the ass passenger rear plug !
#22
I twisteed and twisted and those things took forever to break free....
Has anyone purchased new wires? Curious because the wires being fed around the back of the intake manifold is a HUGE pain. Anyone just go directly over the top of the intake manifold. If you did it loooks like it would work as the plugs dont touch it at all.
#23
I ran the wires the exact same way the stock wires were run.
Your a FOOL it you think spark plugs will last 102,000 miles. I noticed when I changed out my stock ones that 2 of my plugs had cracked porcelain...no wonder why I was getting a rough idle and bad gas millage..
#24
I also tried the E3's ... did feel a difference, got a slight gain mpg.
But, had the same problem - cylinder3 fouled. Replaced the plugs with the OEM's I had removed and issue was resolved.
Overall don't think the E3's are as reliable as OEM's ... Just my opinion
Currently running OEM's ...
#26
I keep meaning to check my gaps because my engine has a slightly rough idle. Try telling that to the stealership though: "Diirrrrrrr (scratches his butt and picks his nose).... I don't feel no rough idle. Diiirrrrr.... I'm a complete retard because I work at Chrysler...."
#27
Same here......changed to Bosch IR Fusions with Granatelli Wires - runs smoother - slight gain on MPG
#29
I just did a tune up last weekend. Here are my lessons....
I have an 07 with about 69k miles...
....One of the wires was so stuck the metal connector stayed onto the plug as the boot broke free (and yes I did not pull from the wire. I pulled from the boot). Breaking that wire was the biggest pain in my ASS. You CANNOT find spark plug wires ANYWHERE besides at a stealership. Trust me, I called everywhere. Stealership wanted about 75 bucks. I had no choice.
Lesson: everyone pull those wires now and lube them. It will save you so much heartache
