Softtop leaks
Mine didn't leak when I got it. Round the second season it started to leak (only when it rained btw) and now it doesn't seem to leak much anymore. So I think if you just not freak out that it leaks a little the problem will eventually go away on it's own!
My windows had a gap in the top front letting water in. I put two small pieces of stickyback foam on the underside of the rag top window where the plastic extention goes down into the steel door. Just on the front, not the back. This aligned the window to the frame of the jeep top.
Rag tops are gonna leak alittle, it's there nature.
Good Luck
Good Luck
Check this write up out from another forum member. Great write up and fixed all my problems.
https://www.jk-forum.com/forums/show...t=softop%20fix
