Soft Top Zipper
I put split rings (key chain rings) on the all my window zipper pulls so I could hook my finger in there. It makes it easier to guide the zipper and increases the torque I can put on the zipper to get around the top corners that are always the toughest spots for me.
I took a votive candle (parafin base) and warmed it up in a cup of water in the microwave. Then I rubbed the candle along the entire zipper length on both the rear and side windows. I also leave the left sail detached from the vehicle when starting the rear window zipper. The zipper pull glides along smoothly with no snagging. My JK is only 2 months old.
If you do lube, use a dry lube or else road dust will gum it up.
Everything has to be put together just the right way for the zippers to come to the end of the track. I found good ol' WD-40 helped out the zippers a lot. Forget rolling the window up, it blocks your rear-view and scratches the hell out of the plastic. Fold it down into the trunk instead.
This was asked about year or so ago, and the suggestion (in addition to all these) is to use divers wax. Go to a diver place and get some, about $4. Mine is called Aquaseal. It works great. I applied it before I put the windows back in after sittin' in the garage for the winter, and zipped right up. I also apply it about once a month depending on conditions. Don't keep it in the jeep, it will melt. It will make it easier and will stay on for a while, even if it rains.
Originally Posted by htweelz
That's a great idea! I'm stealing it. LOL
