Soft Top Windows
#21
Great way to fly!
#22
Originally Posted by Interstink
Ahhh... We are in fact talking about rolling it up on the jeep. Just un zip both sides to the top, roll up the window and put the loops ( loops came with your soft top, snaps inside rear bow) around both ends.
Great way to fly!
#23
The straps came packed with your soft top windows or hardware. They are elastic loops with one snap on each. Look inside the rear roof of your soft top, you will see one snap on each end of the rear top.
#24
I have read a number of times it's not a good idea to drive with side windows and rear window removed, may damage the rear sail panels, for the obvious reasons. But I like it like that! This will be my first summer with an Unlimited (4 door), and I can see myself just rolling the rear window up and leaving side windows on. It was a diff. experience with a 2 door.
#25
they might but you could check an army surplus store im pretty sure they should have some or else you could check quadratec or any other site that sells jeep softops maybe walmart or whatever...check around google search zipper lube or some combination like that. Ive seen it before i know its out there
#26
Nope, seen these on jeeps for awhile now.
#27
BTW... Some have found there Loop Straps in the glove box or center counsel.
#28
Rear Window Rollup Pocket!
I have an idea. What about having two thin towels or other soft material sewed together (3 Sides) creating a window pocket. Unzip the window on both sides, side the pocket on, and roll it up. Should add the protection some of you crave.
#29
I got that zipper lube from the dealer, actually wasn't too pricey. Quadratec sells a really good soft top cleaning kit for 35 bucks. The window polish works great.
#30
You may actually have better luck with the liquid kind if yours are stuck and then use the chapstick stuff to keep it maintained because the stick wont be able to get to the teeth that are stuck very easily like a liquid can.
