soft top/sound bar slap
just the 07's i guess. i noticed at hiway speeds with the windows down some, the soft top will slap the speaker bar due to wind buffering. there is a tsb on it.
http://project-jk.com/images/tsb/TSB_23-046-06.pdf
they install a foam kit. just wondering if anyone did another fix? i am sure some camper foam or other method would work.
You can use 2 soft nap paint rollers for the fix.They hide under the top and you can't see them. Just go to Lowe's and get whatever thickness you need. That's what I use on my 08 2 dr Rubicon.
ok.....sounds like a plan. and where did you place the rollers? would a pic be out of the question?
i would like to follow up on this.
Eternal ***erator
mopars fix is a thin layer of foam to deaden the noise, not stop the flop. there is a depression in the top of the soundbar, a $1 pool noodle cut to length fit perfectly for me, it stops it from flapping far more than 3/32" of sticky foam would ever do.
http://secure.poolcenter.com/prodinf...LAID=143558522
and may i ask how you installed it? i know about the 3 small inditations above each speaker. (backside). i played around with some foam today, but it was just not going to stick. the adheasive was not good enough. could i bother you for a pic?
thanks
dave
Eternal ***erator
yup, that looks like the same thing, except the one i had was gray. i dont have any pics, but all i did was hold it up there from the front seat, guess on length so it went all the way across & cut it off, then shoved it above the soundbar. no trick involved, couldnt even tell it was there from the outside. I would go take a pic but the kids nabbed it for camp and i didnt get it back, havent gotten around to grabbing another one yet.
Eternal ***erator
actually a lot of threads on this, this one shows foam placement pretty well: https://www.jk-forum.com/forums/modified-jk-tech-2/soft-top-8-dollar-flapping-fix-37995/
Eternal ***erator
i cant find a pic of the highly classified pool noodletech installation. I know many of you have done this i read many people had... anyone got a pic to share?
