Soft Top help in closed position
Is this what the top is suppose to look like in closed position? I installed the softtop last weekend as its warm out. But the top doesnt seem like its closed all the way even though the hook clamps are closed on the inside.
Originally Posted by Paws
Is it suppose to be that far away from the windshield?
The top actually sits on top of the channel that is attached to the windshield frame.
The rubber channel is just a big seal/rain gutter. As long as the rubber parts you showed are poked down, you should be good to go.
The stuff poking up goes away when you ensure you clip the top when it's level and straight and after you clean the seals. Dust/dirt makes it catch up on mine.
Mine works that way, and has never leaked.
Good luck
Originally Posted by 2008fx4
thats how mine fits on my 2011 as well. another interesting thing i thought is that the soft top just sits on top of the door molding pieces. it in no way attaches or clips on in any fashion. just held against it by pressure.
??? Theres a cable running along the front where it clamps? I dont think ive seen that.
Although there are cables running along the left and right side of the soft top. From what I understand this is what jeep went to in the 2010 models to replace the pull over and snap soft top above all the doors.
Im just concerned about the front but I will try and tuck the rubber gasken in like another users stated.
Thanks!
Thanks!
No matter what you do... Your better off than your neighbor with the hummer over there (2nd pic).
Good luck... I'll be trying my soft top when winter breaks here...
Thanks!
