soft top hardware help
I just recently bought a used soft top that was missing some of its hardware. After doing some research, I managed to hunt down mostly everything. The only thing I can't figure out is what type and size screws are needed to attach the actual top to the roll bar brackets. I have four torx screws that attach the brackets to the roll bar (at least thats what I think those are for). But I'm need to find the screws that attach the bow to the brackets. Any help would be greatly appreciated. Thanks.
If I understand what you are looking for these may work and they are quick disconnets too.
http://www.quadratec.com/products/11033_002.htm
This is the screw that attaches the bow to the sport bar bracket. You can probably get a similar shoulder bolt at a local hardware store, the head will probably be different but the screw would be the same if you can find the size. I labeled the sizes of the threads and the lengths and diameters, you shouldn't have too much trouble finding something like this in a good hardware store or a fastener store such as Fastenal. Hope the info helps you.
