View Poll Results: Does your soft-top have plastic pieces in the sail panels?
YES
40
78.43%
NO
11
21.57%
Voters: 51. You may not vote on this poll
Soft Top Corner pieces??
I just got a deal on a Sunrider top for my 2 door. My standard top that came with my '07 X did not have the plastic stiffeners in the sails. The Sunrider I bought came with an '08 Sahara and it does have the stiffeners. I don't see any difference when going down the road but I have not yet taken the windows out of the new top and run with top up and no windows. Perhaps the stiffeners will help ease the billowing of the sails when running in this configuration. Just a guess though.
same problem with my dealer
ok i have am 08 x dual top group and sunrider as well it was 7 months after purchase before i swapped them before summer. when i first tried to put the soft top on i thought i was an idiot because i could not get the rear panels to attach i felt like i was going to break the top to force it on. so i was worried id f-it up so i called a long term jeep owner buddy of mine to help me.
he was just as confused as i was. no matter how hard we tried it would not fit right. my inserts would fold an roll the last two inches to make it fit on the inside of the tub. if the insert was under the piece that fist under the tub to secure it on the jeep it wont fit.
i live a few miles from the jeep dealer so i went and asked the rapist, i mean salesman for his input....surprise he had no clue so i asked him to grab a set of keys for a model on the lot so i could see how it was installed....didnt help so i went and checked every soft top jeep on the lot and it was a 60 40 split as to weather or not they had the insert. 40% had them.
i personally think that jeep puts them to make up for the slack when the tops are cut and fitted im sure they stack and cut a pattern of twenty tops at a time like blue jeans. so if your off by 1 degree off center of a perfect cut all the tops pay and the bottom few could be a 1/4 in shorter than the top kinda like a revers trapizoid, or or upside-down gold bar.
i just took mine out and will replace them when the soft top goes in for long term storage.
best of luck with the soft top...im dropping mine off in a day or two to have all the bows replaced because of rust and corrsion, around the sunrider brackets, from the leaks
Last edited by aclokwerk; 07-21-2008 at 07:16 PM. Reason: doh for got to spell check again
the service guy told me that apparently they've changed the design because this is the only kind of top that he could find, unless they take one off of a Jeep on the lot...and even most of those have the top without the pieces. So, no big deal..I'll keep it, it's still under warranty so if it screws up I'll deal with it then.
I figured out a way to roll my sail panels up and secure them with velcro and use straps from an old bike carrier to keep the top secured. I do not have the plastic support piece, so rolling it up was not a problem. I'll get some pics and post what it looks like, but it's holding well and now my sail panels are not get pulled and stretched when driving down the highway.
