Soft top bracket help
One of the attachments for the soft top bracket (the one that latches onto the windshield rail and you clamp it down to snug the top) busted on one side of the bracket (the part that both the latch "c" curve and the bracket handle attach to the bracket itself). Outside of spending the $60 to get a new one, is there an easy way to fix this or a workaround? Right now I have a brad-nail in the hold but it's not as secure as it should be and the roof whistles something fierce...
Thanx!!!
Thanx!!!
Thanx!!!
Thanx!!!
Mine is an 08 and it broke about a month ago (right side), took it to the dealer and had it replaced under warranty. Don't know what to use to fix it as it has a press fitting holding it in place.
Hope this helps
Reg
