so no way to fix whistling from windshield replacement?
My replacement windshield (factory Mopar replacement) whistles at 35 mph and above. Figured I was alone with this, its been 5-6 months.
I just figured I would live with it, but how is it such a commom issue with replacement glass, especially factory glass?
Whistling
See "What's your opinion of my Jillys" in show and tell for photos. Placing the glass wrong can cause whistling without a leak. First quick fix was more mastic to fill gap around entire glass edge. Next installer placed black plastic trim around edge. Now my glass can last long time and take lots of hits without cracking. Two Canadian winters was the record with over 20,000 kilometres. The pic of the Jillys on the power line shows the trim well.
I had the opposite problem. When I had my factor windshield, I would get a whistle a certain speeds. When it was replaced due to a chip, the whistle went away. I was told by the windshield replacement guy that my factory winshield was crooked. I don't know if that's what cause the whistle, all I can tell you is that the whistle went away with a replacement windshield.
I think my factory one makes noise, but it's hard to hear over the tires, wind noise on the hard top, exhaust under the cab, and radio jamming Michael McDonald
To the OP: the windshield just needs removing and re-installation. A small deviation from a perfect install will whistle. On my last jku II had a cracked windshield replaced twice before it didn't whistle.
Mine whistles at about highway speeds, I thought that's just how JK's are due to their removable top design. I guess not. My windshield was replaced as well. It even leaks after I wash the Jeep. I think it shouldn't be too hard to fix it without reinstalling the windshield. Sealing the edge with a silicone, that is normally used in bathrooms/kitchens should solve this, no?
My 2013 whistled right off the lot at speeds over45mph.
Dealer fixed it under warranty and found out it was a
twisted gasket at the lower driver's side corner.
No more whistling now !
Rob ....
Rob ....
