Slamming Doors Shut
Old 12-08-2007 | 10:31 AM
dustin323's Avatar
A crack in the window makes them easier to shut, but a nice slam is easier than all of that. I don't seem to have to slam them as much anymore. I guess I got used to it and maybe I started using the old hold the handle untill all the way shut trick and didn't even know about it.
Old 12-08-2007 | 10:33 AM
dustin323's Avatar
Originally Posted by IndianaJK
Yeah, I have to shut mine like that too.
When I have a passenger with me I make sure I leave my door open until they shut their door first then I shut my door. I feel like an ass having to tell everone to shut their door again.
I like bitching at my passengers to shut their doors again.
Old 12-09-2007 | 04:18 AM
cmh2001's Avatar
I have a hard top. My driver side door always closes good. It seems my passenger side door is never closed (even if I close it). I've played with the alignment a little bit by taking the hinge off the outside of the door. I can't say that I've made any progress though. I'm gonna have the dealer look at it the next time I go in.
The back doors don't get used that much, but I don't recall having any problems with those doors.
Old 12-09-2007 | 07:49 AM
FlightTester's Avatar
Originally Posted by csims723
I found it all in the follow thru. you can't just shove it and it close. You have to keep movement and pressure on the handle until it closes. Its fairly easy if you just keep your hand on it.
Same here. When I was closing my doors like a "car" my Jeep mocked me. Now that I use proper form (essential for all sporting equipment), my doors close properly.
Old 12-09-2007 | 01:24 PM
101gargoyles's Avatar
Former Member
Anyone that has removed their spare tire knows that the vehicle is not air tight due to the vent with the rubber flaps behind it.
If you are having REAL problems closing the doors adjust the latches.
All vehicles have these vents or the heating/cooling system would not be able bring in outside air with such a small fan.
On cars they are usually hidden behind the rear bumper.
Old 12-09-2007 | 02:19 PM
Skoalman's Avatar
Originally Posted by N2rock
so they think the thing to do is just swing harder.
1:
Oooh man, there was almost a divorce over the slamming of the doors.
I told her if she slammed my doors one more time, I was gonna make her ride in the hitch haul.
I hate sleeping in the barn.
Old 12-09-2007 | 04:36 PM
Timdelta's Avatar
If the doors shut easy with a window open, and hard with the window shut, it is a air pressure problem and not a latch. If it is hard to shut with the windows closed then the vent in the back is not enough air flow at such a rapid rate of change.
Old 12-09-2007 | 06:48 PM
mt3's Avatar
mt3
good call ...
agreed with hardtop ... it's hard to close ... not with softtop ...
Old 12-11-2007 | 02:47 PM
jetsfan28's Avatar
I did a quick experiment. I laid a sheet across the hardtop and down the passenger side, with only the rear passenger window open about 4 inches.
Then I opened the front driver's side door and closed it with normal force.
The force of the air coming out of the 4 inch opening was enough to blow the sheet right off the vehicle.
So yes, there are vents in the rear gate, but they aren't sufficient to handle all of the air pressure when a door is shut...
Quick Reply: Slamming Doors Shut
