Sahara wheel protection
Old 04-04-2009, 05:35 PM
rjhoop's Avatar
Originally Posted by JK Freedom
You have rims made of aluminium. No problem with salt...
thats not true but yours are clearcoated so no proublem just wax em
Old 04-05-2009, 07:27 AM
RevyJKU08's Avatar
Clearcoat is already damaged from factory, The dumb wheel weights clipped on the outside have damaged the clearcoat on the rims and salt water & grim will eventually get under the clear and flaking the clear away and once that is done...you may as well just use the rims for winters or get them powdercoated.
Old 04-06-2009, 06:03 PM
swanni06's Avatar
soap and water..wax wears off fast on wheels,it does help but not like just keeping them clean will.
Old 04-07-2009, 04:38 PM
TINMAN080's Avatar
Wheel clearcoat is several mils (thousands of an inch) thick on the flat and curved surfaces of any painted surface, including your clearcoated wheels. BUT any area of the wheel that has a SHARP edge, such as the spoke openings and the lug nut holes the clearcoat will NOT adhere to the sharp opening edge with any depth. This is the weak point in your wheel clearcoat. Keeping the wheel washed and waxed is your only defense, road film is very corrosive on a wheel. Look at any corroded or weathered rim, the earliest and most damaged areas start at the sharp edges and work their corrosion inward under the thicker coating areas. Keep 'em CLEAN....
Quick Reply: Sahara wheel protection
