Is a Sahara any better than a base model?
#121
quote My X has the same ground clearance as a Rubicon, which is only slightly greater than the Sahara.
How can x have same clearance as a sahara when sahara has the best stock ground clearance even better than rubicons
X comes with 28" tires
sahara 32.1"
rubicon 32.05"
sahara by a 1/4"
sahara 32.1"
rubicon 32.05"
sahara by a 1/4"
X models with the S23 or S24 option (different option # for 2010) have 32" tires on alloys.... This constitutes the bulk of X production. Basic X models are in the minority. The Goodyear SR-As on the upgraded X measure 32.1" in diameter, identical to the Sahara's rubber.
My regards,
Widewing
#122
That's acually not true. The Sahara has an 18" wheel and has the largest OEM tires. You are correct that they are about the same size as the Rubicon tires. Same tire size IIRC, but the exact dimensions just vary by brand/tire type.
#123
I read the same specs that the Sahara tires should be taller. However, I took my Sahara tires off and put Rubicon tires on. Before I did I stood the unmounted tires side by side. The Rubicon tires stood a little taller. Go figure?
#124
http://www.bridgestonetire.com/tires...roduct_ID=1114
Thus, ground clearance is exactly the same, barring large differences in tire pressures. Wheel size is irrelevant in this case. Tire section ratio determines diameter.
My regards,
Widewing
#125
I don't know if I suck at measuring or what, but back at our old Jeep store, I physically measured a new S pkg X, Sahara, and Rubicon and that's what I came up with.
#126
Wax arounbd the logos, etc
This is my first post so here goes...
An old show car trick is to use a very soft toothbrush gently around all the letters and decal edges to get the wax off that may be built up around them.
I used to have a 2003 rubicon and the gloss clear coated fenders made it look like trash when they got rock chips from the road. It also rode very hoppity.
I traded for a 4 door unlimited X with the power windows, etc group and got a Detonator Yellow model as I darn sure can't lose it in any big parking lot. The ride is greatly improved and we like it a LOT more.
