Rubicon Locker Connector Removal?
i removed my axle assembly to install sleeves and gussets. In order to pull the axles out I need to disconnect the connector from the e-locker in the differential. I don't see how to do it and I don't want to break it. Anyone know how to disconnect the connector inside the housing on the locker?
Thank you.
Thank you.
Thank you.
Thank you.
Yes. I have the axle assembly on the floor. going to pull the axles and carrier out.
On the Teraflex site I found instructions with a pic of the connector. It looks like the blue wires disconnect from the bottom of the connector that is on the top of the differential. I'll give that a look in the morning.
Thank you.
Thank you.
