Rubi Shocks & Springs 2dr versus 4dr
Spring rates vary depending on the options; 2door vs 4door, half-doors vs full, softtop vs hardtop, Tow package vs none, Rubicon vs non-Rubicon. The stiffest spring rate comes on the 4door Rubicon with hardtop, full doors and tow package. Although the Rubicon springs are not taller (no lift), they will cause an equal/lesser weighted JK to sit higher, because stiffer springs sag less.
The gas shocks of the Rubicon are also far superior and will hold up longer to abuse than the stock shocks.
You'll notice a difference swapping in Rubi springs/shocks.
Just found out from moparpartsamerica.com that the front springs are left and right. p/n 52126315ab (zdf zsf) is left, p/n 52126316ab (zdg zsg) is right. Rears are the same.
