Rubi Differential question
The next logical question is WHY would jeep make the differential lockable ONLY in 4lo? are locked diffs in 4-hi hard on the drive train or something?
So, I'll gladly admit I have a lot to learn about 4x4 and off roading..
I think I understand the purpose, and difference between locking, and limited slip differentials.. but it seems to me that a vehicle in 4 x 4 drive without either is not truely a 4x4 as it should send torque to the path of least resistance.. the wheel that won't grip.
Which brings me to my question.. I believe the rubis have Dana 44 axles.. and I know that they're lockable in 4-lo.. but what about 4-hi ? Are those axles ALSO limited slip?
I've also read about the electronic braking differential, and the braking methods for traction control.. Are THOSE what a fella has to rely on in 4-hi to get traction? seems like it would be hard on the hardware.
A locker closes the diff and makes both wheels spin at the same time. A limited slip sends some power to the wheel that isn't slipping. Lockers and limited slips add a lot to 4 wheel drive but aren't required for it to be 4x4. In most road driving conditions a limited slip is more desirable as a locker is pretty much only useful offroad.
Braking methods for traction control are pretty much to trick limited slip differentials into providing more traction under pretty specific conditions, which are usually off road.
D44 axles aren't necessarily locked or limited slip. Just like any other axle it depends on what is installed. On a Rubicon the D44 has an electronic locker. They aren't limited slip per say but 07 and up has electronic stability control which transfers power to wheels with traction and away from wheels that are slipping. It's pretty impressive how well it works in slippery conditions. That is not
I thought that was why Chrysler offers the Unlimited as a 2WD as well. The words "wrangler" and "2WD" just sound so wrong when put together, don't they? Damn you soccer moms; why don't you get a BMW X5 or Range Rover Vogue like all the others?
