rough starting!!!????
Hey yall,
When ever i start my 07 after its been sitting for awhile, its really rough sounding for the first couple seconds. Oil is full also. Any ideas?
Originally Posted by jdelia2012
Hey yall,
it's not the best solution but if it has sat for a few days...floor it when you crank it over...it won't start but will prime oil back into the filter and top end..then stop cranking, release the pedal and start as normal...no dry start! It's probably not great for the starter but I'll replace that a little sooner then let my motor dry start in the cold...hopefully in your case a different brand of filter fixes it and you will be good
Yeah sounds like oil going back into the pan. Was happening to me, and after I changed my oil with a new wix filter the problem went away. Just invest in a good quality filter.
