Rotors
Yes. Removed calipers and it even had locking washers holding it which I removed. Working this SOB to death without damaging things. Thanks for the reply. Can only keep trying.
yeh rusted on
big hammer will bash them off just keep hitting them in all areas
new rotors will be goin on anyway /not worth turning them so damage isnt issue
you can get rotors for like 40 a piece another method that works good is
a small bottle jack from behind will push them out to you
you could put the bottle jack base up against track bar bracket and the cylinder up against back side of rotor should pop it free ussually easyer than banging
Do not use a bottle jack against the track bar bracket. Soak it with your lubricant of choice and keep getting it.
Remember to put some anti-sieze between your rotor and hub when you go to put it back together.
wont hurt anything works fine
theres not enough pressure to effect the bracket in any way and if it was on that bad you have other issues sometimes they just need a little pressure from behind to pop it ( but yeh anti sieze is a good suggestion
+1 Soak with liquid wrench or PB blaster, let it sit, then start hitting it top, bottom and sides.
bottle jack works great too
it will pry the rotor away from the rusty bead that forms around hub to rotor you can also try using heat too but i like the bottle jack method best it works effortless every time i suppose you could keep lubricating and keep banging and getting it
