Rookie Soft Top question
use the Torx-40 bolt that holds the hard top on over the b-pillar to bolt the plastic frames for the soft top down. i had the same problems as you, i even had leaks at the b-pillar until i did this. the only down side is you have to leave the plastic rails in place when the soft top is down - unless you want to unbolt them every time.
