Returning to stock
It was a 2.5in Rough Country coil spring. Rear trac bar relocation bracket, and rear sway bar disconneted from Sky jacker.
It feels like its going to run away on me. No play in the steering but real jerky.
I installed it at the JBLM autoshop, all bolts were torqued to spec, all springs seated properly. Trac bars was installed on the ground, and it was aligned right after the package was installed.
(when you lift front goes left ,back goes right) that helped it wandering -bump steer ,, then put longer sway-bar connecting rods
front & rear that made small bumps like driveways so much better . messed with caster but ended up back at stock ..
Thanks all,
I've got some time to mull it over. But I will contact you if I am interested in purchasing your suspension components. If anyonelse wants to sell their suspension components, or possibly a in the shop swap, I'll pay for the shop fees, and give you hand in the installation. Just throw up a PM, or reply to the thread.
-Jeff
-Jeff
i hate to see a fellow soldier suffer. (also currently in Afghan) With that being said, i will take the lift of your hands so that you will no longer have to deal with it. in shop swap sounds great. i won't be at Ft Lewis until late summer though.
seriously though,
stock suspensions are a dime a dozen on CL. 100 buck or less. or even add Rubicon springs
(18/19) and shocks for that price and get a little boost with a stock feel. then you would be able to package your lift and sell it to get some of your money back.
also, a good shop should be able to help you get you what you need to get your lift to ride a bit better.
seriously though,
Jeff. I try to tell people about this all the time. Lots of people say that they can live with a mimimal lift just like yours. I would be in the same boat as you. I couldn't live with what you are experiencing either. But the stearing problem is easily fixed. You just need a couple more parts to make your lift more complete. Your over half way there. I'd hate to see you turn back now.
