replacing fender flare side light...Help
I broke right fender flare side marker light. I ordered a new one online and when and as soon as I tried to replace it I realized that there in an inner plastic liner held by plastic rivets preventing access to the side marker. So my question has two parts:
Has anyone changed the Side flare and can guide me as to what to do.
Is there a place online when I can get a bunch of Mopar plastic rivets (parabaly good to have some extra one) and do I need a special tool to put them on.
thank you.
thank you.
If you go to Quadratec's website, you can download the instructions for the Bushwacker fender flares. This is what I used when I had to remove mine. Its rather quite easy.
I have some extra clips so let me know what you need and I'll send them.
And no special tools needed. A door panel/trim tool remover makes life alot easier when removing the flares. You can get it at Advanced Auto Parts or Pepboys.
just pop out the rivet at the front of the fender wth a screw driver.Have a second person hold the inner fender back and you will have access to the light. you can reuse the rivet.....You can look for directions for rugged ridge sidemarker covers it will show you the pictures of how to remove it. It is easy if you have two sets of hands.
I held mine apart with a wood wedge while I installed the guard. If you work the rivets out acrefully, you can re-use them.
