Replacing ball joints soon
I will be replacing my ball joints soon as they just started squeaking with 125,000 miles on them. I'm going to replace with Synergy ball joints. My question is with regard to tools. I'm wondering about people's experience with Harbor Freight ball joint kit vs getting loaner tools from Auto Zone? Which would make the job easier? Trying to make this as pain free experience as possible. Thanks!
I used a rental from the local parts store. It had everything I needed and it was free. Make sure you have a good size breaker bar. My passenger upper ball joint just didn't want to come out. I was putting so much force into it that my jack stands and jeep slid across the garage floor a few inches before it finally released lol
There are a bunch of write-ups online
Good luck!
Good luck!
Borrow the tool kit. The C is stronger than the ones in the cheap kits.
Instead of putting a ton of force on the press, tighten as much as you can with reasonable effort, then give it a few strokes on the top of the screw with a 3 or 4 pound hammer. I did this and they popped loose after a few hits.
You should make sure the kit has a tapered spacer. It makes the new top ball joint much easier to start in the hole.
Otherwise, you'll have to put washers under one side, trying to keep them in place as you go.
Plus 100 on getting an angled spacer like the one above or you will have to find some metal shims or the angle will kill you trying to use the flat spacer. Also something that helped me was the use of WD40 penetrator not the regular one and soak the edges in the stuff the night before working as it does help. Patience and raw strength are all that's left.
The tapered adapters are Dodge/Jeep specific if you buy them. The taper is very slight. If you go to borrow and it doesn't have the Dodge/Jeep specific adapters, your job will be more difficult--you could end up getting a balljoint not fully seated. You wrote you wanted "easier". Easier is the proper tools ...
http://www.amazon.com/OTC-Dodge-Join.../dp/B0002SRGW0
The tapered adapters are Dodge/Jeep specific if you buy them. The taper is very slight. If you go to borrow and it doesn't have the Dodge/Jeep specific adapters, your job will be more difficult--you could end up getting a balljoint not fully seated. You wrote you wanted "easier". Easier is the proper tools ... http://www.amazon.com/OTC-Dodge-Join.../dp/B0002SRGW0
Going to tackle this ball joint replacement soon. Thinking of possibly changing tie rod ends too because my drag link was bad and ball joints. With 125,000 on her I figure tie rod ends won't be far behind. I only want to have it aligned once, so I'm wondering if I will need an alignment after replacing ball joints? If so I will do tie rod ends now, but if not I might wait.
