Replaced Evap can and...
Hey yall... I finally got all the pieces in to replace the evap canister (ripped it off wheelin') and the gascap light and check engine light are still coming on. Yes I already checked all the hoses and ect... Does the computer need to be reset to clear this or should it just reset on its own?
Anyone have to deal with this yet? I know I'm not the only person to replace the evap...
1. When you took off the white part (scientifically called the white thingy with the electrical connection,) did you examine it carefully for cracks? POR15 is immune to gas fumes and will seal any cracks in it like nobody's business.
2. When you put it on the new cannister, did you check that green gasket carefully to make sure you had a good seal? (I even used a little silicone on it.)
3. When you put the white thingy with the electrical connection back on, did you make certain to install it the same way it came off? (So the electrical connector is sitting in between the two hose connections.)
4. If you relocated it, did you put it back in right side up? (With the three plastic tabs pointing up?)
5. Did you throw in a boatload of silicone dielectric into the electrical plug before hooking it back up?
6. Did you disconnect your battery while doing all this? One fellow advised me to turn the ignition switch to on after disconnecting the battery, then turning it off before reconnecting. I don't see what difference that would make, but what the heck, it's an easy thing to do. I found thirty seconds was long enough to erase those two codes. Longer than that didn't hurt anything.
I think the issue I struggled with was that I reinstalled mine upside down. Go figure. I haven't had those warning lights come back on since doing all of the above. (Hope I didn't just jinx myself.)
Good luck!
Good luck!
Hmm....
so, there has been another thread commenting that the cheapo plastic evap can is a danger. was wondering, did you drive the car after this happened? I would assume not
Search the site and you'll find out tons of info on all this. As you find out more about this, you'll see it's drivable without it although you should find a way to keep the raw gas fumes from leaking out while waiting for the new parts.
BTW Welcome to the forum.
I had to seat the green gasket between the evap can & the ESIM switch (white thingy) and turn it (ESIM) 90 degrees. But I messed with the whole unit.
As far as driving with the evap can torn off... i drove the rest of my road trip (1000+ miles) and every few days around town when I got home and never had a problem. The way I see it, if it was that dangerous you would hear stories and news reports of me (or anyone else) getting "blown up" when they got rear ended...(holy PINTO!!!)
It needs to be addressed asap, and not to make light of it but If it really was that dangerous I have a hard time beliveing that DC would knowingly rush the JK out to the market knowing there was such a danger... I mean its not like they would just release a vehicle that stalls in the middle of an intersection... umm, i mean... Oh hell...
WERE ALL GONNA DIE!!!
There was a fellow on here a while back whose brother's JK went up in flames and was crisped in 9 seconds or so. There was some thought that it may have been due to (dare I say it) my favorite part on the JK.
Other than that incident, I was thinking those fumes would be minimal as well.
BTW, you forgot to mention the reason you were sitting there stalled out in the intersection in the first place: YOU COULDN'T STOP BEFORE THAT!
