removing powder coat
can i use a chemical paint stripper to remove powdercoat off of some rugged ridge aluminum rims that need to be recoated?
is sandblasting better?
looking for the cheapest option to prep properly for a satin black krylon coating
1 Post
If it were my project I would avoid chemical strippers and sand blasting . Both are too aggressive for aluminum IMO. I'd start by blasting with walnut shells. If that was too light a touch then plastic beads would be the next step. Neither of these will leave pits in the aluminum.
I've used this, worked great.
Attachment 158982
Permatex gasket remover. Spread it on the surface, let it sit a good 15 minutes and then wipe off with paper towels/rags. Some areas require more than one application.
The part I was stripping was aluminum. No damage or ill effects.
Attachment 158982
