Rear license plate relocation
I bent band stock aluminum. It attaches via the top stud for the spare. Basically, it takes the sauce of the spacer for the lug lights. A couple bends to get the angle & height correct, riveted an angle piece to the top. Painted with bed liner and attach. Drill holes to attach light, plate, etc. then, I wanted a clean look so I installed "lightnin' bolts". Those are the led bolts holding the plate in place. Inexpensive and are actually brighter than what the pic shows.
I have this bracket and there's actually 3 wires. The ground, red (brake light), and green (tag light) that need to be tapped into your current wires.
Black goes to black from the passenger taillight wires, red goes to the white with gray/brown striped wire from the third taillight writes, and green goes to the white with purple striped wire again from the passenger taillight wires.
Attachment 590830
Attachment 590830
Warrior spare tire brake light and license plate mount.
Warrior Products 2380 - Warrior Products Spare Tire License Plate Mount with 3rd Brake Light - Quadratec
The plate/light is easily removed with a single clip. I used 4-pin trailer light plug so the wires also easily disconnect but are water proof. (Dielectric grease helps on trailer plug.)
The light/plate bracket also provides a mount for my back-up camera. (red arrow)
