Rear header rollbar bolt size
Does anyone know the bolt thread size of the two bolts that attach the rear header to the stock JKU roll cage?
For those with the Trek Top NX, it's the bolts you remove/install when you put on the spring tension brackets. I stripped one of the holes and need to run a tap down it to recut the threads.
The bar is #3 in this picture.
http://stores.revolutionparts.com/fa.../roll-bar-scat
